Forum /
THE MAIN WALL /
Infloor Sensor
Post a Reply to this Thread
Infloor Sensor (4 Posts)
In the past
I used the tekmar 500 series or the Wirsbo equivlent. On the past few jobs I used a simple basic setpoint control. I mount it in the mechanical room, as they are not the nicest looking control. But it also keeps folks from "over adjusting" The tekmar is a nice conmtrol, tough to wire, odd shape doesn't cover a 2X4 electricial box, and somewhat confusing to homeowners to adjust and program. I'm going with the Heattimer setpoint as it has a large display and is very simple for the average homeowner to drive. hot rod To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional" -
What do you guys typically set the in floor sensor to in bathrooms and kitchens? Jamie To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"
Thanks Hot rod! I mounted the two bathroom sensors in the linen closets and the kitchen in the pantry. I have them set to maintian a floor temp. of 70 degrees. Do you think that is enough or too much? Jamie
If the sensor
is mounted to the bottom of the subfloor, I've found somewhere around 85 or so. It depends on the r value of the build up above the sensor. If the sensor is emmbedded in the backerboard or touching the tile itself 78-82 seems to be the comfort range. Most times mine are installed under the 3/4" subfloor and the tile backer board. Bottom line, let the owners adjust it till it hits their "sweet spot" I back my bathroom floor stat about 5 degrees in the summer time. I like to just take the chill off the tile without overheating the space. The main reason I am changing stat brands is to allow the owner ease of operation to fine tune to their comfort range. Keep the differential tight, 2-3 degrees is about right, I've found. hot rod To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"
